  • 1.  Export Users in MAS
    Posted 03-16-2026 12:27
    Hi Team,
    I need to bulk update expiry time for users in MAS.
    Is there any option to export users in MAS so that we can bulk update require data ?
    I can see option to import but not for Export.
    below field need to update.
    Manually it's easy to update 1-2 records but not for more.
    JustIn goodLuck
    ABS
  • 2.  RE: Export Users in MAS
    Posted 03-16-2026 12:39
    Hello @JustIn goodLuck. I'm wondering if you are possibly needing to request to have that option enabled (Unless you have Suite level Admin access and can enable yourself)?  When I open Users at the Suite level there is an option to download:
  • 3.  RE: Export Users in MAS
    Posted 03-17-2026 09:18
    Which version are u using where this option available?
    I am using v9.0 .
    JustIn goodLuck
    ABS
  • 4.  RE: Export Users in MAS
    Posted 03-17-2026 10:29
    I'm using 9.1.
    The picture is from the User's application at the Suite level.
    This link might give some helpful information:
    https://www.ibm.com/support/pages/export-and-import-users-data-maximo-application-suite
