  • 1.  GL Default account for Individual Inventory Item
    Posted 06-14-2024 12:40
    Hello all,
    I was asked today if I can make it possible to add a Default GL Account to an inventory item.
    Some Items are only for a specific account and will never change.
    Would this be possible to add as an optional field?
    Thank you in advance,
  • 2.  RE: GL Default account for Individual Inventory Item
    Posted 06-15-2024 01:03
    Yes, but keep in mind that the GLACCOUNT will be assigned at the INVENTORY record, so it can be different on a per storeroom basis and you will need to:
    • Expose the GLACCOUNT attribute / field in the inventory application (INVCOST.GLACCOUNT) in the Costs section
    • Update the field for the inventory records of interest, for each storeroom the inventory record is in that you want the account to default
    This is not something you can do at ITEM MASTER level and expect it to be available in inventory.
    IBM Champion 2024
