  • 1.  Help to determine how this graph was created
    Posted 03-23-2023 14:48
      |   view attached
    Good Afternoon,
    I'm working on some basic KPI's for upper management. My supervisor has a pie chart of work orders by status showing up on her main portal (see image).  The normal KPI's allow only the gauge graph. She is not sure how this was created, it was some time ago. I can go to the results set from the pie cart in work order tracking. Can someone determine by the image attached how this report was created. Much Thanks.
    Keith Henderson
  • 2.  RE: Help to determine how this graph was created
    Posted 03-23-2023 14:59
    That looks like a result set. If you set this up as a result set, you can use the chart option during setup to set the pie chart as default, and assign colors to each status.
  • 3.  RE: Help to determine how this graph was created
    Posted 03-23-2023 15:13
      |   view attached
    Hi Keith,
    In that portlet on the start center, click on the pencil icon in the upper right hand corner to edit the portlet. The next screen defaults to the "Field Configuration" options. You can change the chart type by clicking on "Chart Options" to the right of "Field Configuration" in the blue bar (see screen shot attached).
    Select the dropdown under "Chart Type" to select what you would like it to be, and use the magnifying glass near the "Display By" field to select whichever field you want the chart to focus on. In your example, that looks like the status field. We have result sets that are set to display by lead, for example, and if you click on one specific lead's piece of the "pie," it opens up a list of that tech's work orders in WO Tracking.
    Hope that helps!
    Amy
    Amy Tellier-Briggs
    Maintenance Planner, CBO, BOC Level 1
    Facilities Services
    207.288.6356 t  |  207.266.4347 m
    amy.briggs@jax.org
    The Jackson Laboratory
    Bar Harbor, ME  |  Farmington, CT  |  Sacramento, CA
    www.jax.org
    The Jackson Laboratory: Leading the search for tomorrow's cures
    The information in this email, including attachments, may be confidential and is intended solely for the addressee(s). If you believe you received this email by mistake, please notify the sender by return email as soon as possible.
  • 4.  RE: Help to determine how this graph was created
    Posted 03-24-2023 11:45
    Good Morning,
    Thanks for the input. It was my lack of understanding of Start Centers and Portlets/Results. I watched a number of videos last night, very helpful.
    Keith Henderson
