  • 1.  How to add Multiple Assets to Single Job Plan?
    Posted 10-03-2023 10:00
    Hello all, right now MXLoader tries to create a new Job Plan for each row when trying to add Assets.  So how can I add multiple assets under the Work Assets tab using MXLoader?  Is this possible?
    Thank you
  • 2.  RE: How to add Multiple Assets to Single Job Plan?
    Posted 10-03-2023 11:16
    Go to Object Structure > Search MXL_JOBPLAN. In that add object JPASSETSPLINK and include all required fields. Now you can query 1 Job Plan with Asset and then load all others after removing unwanted fields.
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: How to add Multiple Assets to Single Job Plan?
    Posted 10-22-2025 18:46
    Thank you @Prashant Sharma
    I seem to be having trouble now when trying to add assets to a Job Plan that has no ORG or SITEID.
    I receive this message:  Internal Server Error
    Error 500: BMXAA2147E - Work asset must have an organization.
    I added the columns below and it did not resolve the error so I am assuming it has to do with the Job Plan not having an ORG?
    JPASSETSPLINK.ORGID JPASSETSPLINK.SITEID
    I was curious if there is a way still to add the assets to a Job Plan without an ORG.
    Thank you for any advice :)
