  • 1.  How to create Relationships for Object Structures
    Posted 01-31-2024 17:17
    Are there any articles or videos that can teach me how to create relationships in Maximo?
    Or do you recommend a class?
    Thank you
  • 2.  RE: How to create Relationships for Object Structures
    Posted 02-01-2024 09:22
    Hi Danny ,
    I am not sure if you have already checked trainings / videos on IBM IOT Academy.
    Here is link for Database Configuration topic which can help you
    https://www.ibm.com/training/badge/iot-maximo-database-configuration
    not sure about what you meant by object structure relationships though.
    Prashant B
  • 3.  RE: How to create Relationships for Object Structures
    Posted 02-01-2024 09:45
    @Prashant Bavane this is exactly what I needed, an introduction to these aspects of Maximo.  Thank you so much!
  • 4.  RE: How to create Relationships for Object Structures
    Posted 02-04-2024 13:35
    Hi @Danny Richardson Good Day You can read the article below.
    For Object Level in Database Configuration, which is used to link two objects and can be used in mainly application designers and automation scripts to fetch the dataset from mbo to the child object.
    https://www.bpdzenith.com/the-bpd-blog/maximo-relationships
    And more specifically, to link to an object in the object structure, you can read the below article, which helps you to know how relationships are used at the object structure level, which is commonly used in reporting object structure (Start Center) and integration (migration manager) object structure.
    https://viveknagre.substack.com/p/ibm-maximo-start-centers
    Vivek Nagre
    JLL
