  • 1.  How to enable serach field in maximo Go To Menu Navigation Search field
    Posted 05-05-2025 00:12
    Can anyone help me in enabling Navigation search field in Go To Menu, when you open Go To menu there should be a navigation search to search for modules.
    Thanks in advance
    #Utilities
    Prathyusha Mukku
    LNT
  • 2.  RE: How to enable serach field in maximo Go To Menu Navigation Search field
    Posted 05-05-2025 09:11
    I'm uncertain that I understand what you are asking for. Can you provide more details?
    Stevie Holloway
    Tufts University
  • 3.  RE: How to enable serach field in maximo Go To Menu Navigation Search field
    Posted 05-06-2025 10:04
    In Maximo 7.6, you have to open "Side Navigation Menu" to see the "Find Navigation Item" search field. In the Go To Menu, there is no search function for applications and modules.
    Beat Keller
  • 4.  RE: How to enable serach field in maximo Go To Menu Navigation Search field
    Posted 05-06-2025 19:06
    Edited by Craig Kokay 05-06-2025 19:07
    Hi Prathyusha
    We're very confused.  Firstly, in Maximo 7.6 the default was to have the side navigation menu always open.  So, it must have been set to always close for you or your security group.  Next, what you're searching for is still in the same place, just open the side navigation menu.  This is why we're confused.
    If we are talking about the side navigation menu, then this can still be enabled as it was in Maximo 7.6.  Follow this Enabling the side navigation menu - IBM Documentation
    Principal Consultant
    COSOL
    #IBMChampion
  • 5.  RE: How to enable serach field in maximo Go To Menu Navigation Search field
    Posted 05-07-2025 04:30
    Hi Beat,
    Thanks for your reply. Yes, I don't see that search option in side navigation menu, can you help how to enable that one.
    Prathyusha Mukku
    LNT
  • 6.  RE: How to enable serach field in maximo Go To Menu Navigation Search field
    Posted 05-08-2025 02:00
    I think we should first define the terminology.
    The Go To menu that you can open by clicking on the hamburger icon (three horizontal lines) is not the same as the sidebar. The Go To menu is only visible after clicking on the icon.
    The side navigation menu (sidebar) can be displayed permanently. This is controlled via a system property and can be set in the user default information, for example. See the link in Craig's answer.
    Go To = No Search option
    Side Navigation = Search at the top
    Beat Keller
  • 7.  RE: How to enable serach field in maximo Go To Menu Navigation Search field
    Posted 05-08-2025 07:05
    Prathyusha,
    From the Screenshot that you have submitted, it appears that the UserID you are using is not assigned any Security Group with a "Start Center".  The Message you are receiving behind the GoTo Menu.
    If none of a User's Security Groups are assigned a Start Center, they will not have the Side Navigation Menu mentioned by Craig and Beat.
    Make sure that the UserID is a member of at least one Security Group that is Assigned a Start Center and then log back into Maximo.  You should then see the Side Navigation Menu on the left side of the screen where you can find the "Find Navigation Item" search (You may have to open it as mentioned by Craig).
    Steve Platt
    Maximo Administrator
    Georgia Building Authority
