  • 1.  How to handle Read-Only API Calls from External Applications?
    Posted 07-07-2023 13:18
    I am not sure if this has been answered in another post after searching so I wanted to ask it here.
    MAXREST call - Object Structure - example - my-woAPI  - workorder parent - 10 fields that are read only.
    How do most people address these fields on an update from maxrest call?
    Roger Vallee
    Prometheus Group
  • 2.  RE: How to handle Read-Only API Calls from External Applications?
    Posted 07-07-2023 14:52
    If you're building something interactive, add rsmeta=1 to the request. Editability rules are going to be dynamic and this will tell you what fields are currently readonly, required, have a method of retrieving values, etc.
    EX Request: /maximo/api/os/mxapiwodetail?lean=1&oslc.select=wonum,description,siteid,assetnum,location,status,estdur&rsmeta=1&ignorecollectionref=1&oslc.where=wonum="1001"
    EX Response:
        "member": [
                "status_description": "Approved",
                "$assetnum_meta": {
                    "constrainedValueList": "https://mydomain.com/maximo/api/os/mxapiwodetail/_QkVERk9SRC8xMDAx/getlist~assetnum"
                "description": "12 Month Service on Shipping Dept #1 Conveyor",
                "$siteid_meta": {
                    "readOnly": true,
                    "constrainedValueList": "https://mydomain.com/maximo/api/os/mxapiwodetail/_QkVERk9SRC8xMDAx/getlist~siteid"
                "wonum": "1001",
                "_rowstamp": "102754038",
                "assetnum": "12600",
                "$status_meta": {
                    "readOnly": true,
                    "constrainedValueList": "https://mydomain.com/maximo/api/os/mxapiwodetail/_QkVERk9SRC8xMDAx/getlist~status"
                "siteid": "BEDFORD",
                "location": "SHIPPING",
                "href": "https://mydomain.com/maximo/api/os/mxapiwodetail/_QkVERk9SRC8xMDAx",
                "$wonum_meta": {
                    "readOnly": true,
                    "constrainedValueList": "https://mydomain.com/maximo/api/os/mxapiwodetail/_QkVERk9SRC8xMDAx/getlist~wonum"
                "$location_meta": {
                    "constrainedValueList": "https://mydomain.com/maximo/api/os/mxapiwodetail/_QkVERk9SRC8xMDAx/getlist~location"
                "$estdur_meta": {
                    "required": true
                "estdur": 4.0,
                "status": "APPR"
        "href": "https://mydomain.com/maximo/api/os/mxapiwodetail",
        "responseInfo": {
            "href": "https://mydomain.com/maximo/api/os/mxapiwodetail?lean=1&oslc.select=wonum,description,siteid,assetnum,location,status,estdur&rsmeta=1&ignorecollectionref=1&oslc.where=wonum=%221001%22",
            "totalCount": 1
  • 3.  RE: How to handle Read-Only API Calls from External Applications?
    Posted 07-07-2023 15:19
    As always Steven thanks for the tips here.
    This community owes guys like you two thumbs up!
    Roger
    Roger Vallee
    Prometheus Group
