  • 1.  How To Move Asset in Maximo Through Automation Script
    Posted 05-20-2024 07:41
    There is a Requirement When we Receive Asset  X with a SiteID through Integration If that Asset X exists with Another  SiteID combination It should move Asset to New SiteID received through Integration. Basicly Needs to Move Asset to New Site Through Automation Script.
    Any Suggestions /code Snippet will help
    Reetika Agrawal
    EY GDS
  • 2.  RE: How To Move Asset in Maximo Through Automation Script
    Posted 05-23-2024 09:19
    I am looking for a method which is Triggered from UI when Asset Move is performed from one site to Another so that method can be referred in Automation Script.
    Reetika Agrawal
    EY GDS
  • 3.  RE: How To Move Asset in Maximo Through Automation Script
    Posted 05-23-2024 16:30
    Hi @Reetika Agrawal!
    We imagine ASSET AST-01 in plant A1.
    What Maximo does when an asset is moved from one plant to another is create (or check if it exists) a new record and change the previous one to DECOMMISSIONED.
    You receive with integration the AST-01 asset but with the definition of siteid A2.
    Before the change:
    AST-01 - A1 - ACTIVE
    After the change:
    AST-01 - A1 - DECOMMISSIONED
    AST-01 - A2 - ACTIVE
    If you then receive AST01 - A1 again, what Maximo does will be to DECOMMISSIONED A2 and activate A1 again.
    It would be a script that first analyzes whether the record already exists in said site and makes the status changes.
    If it does not exist, the script must create the new record in the new site and also change the previous state.
