Hi Rob
If you're using the same ID for the laborcode as for the personID or userID, then you can &PERSONID& in the default, but if they are not, then you will have to use an automation script as the PERSONID is at system level whereas LABORCODE is at ORG level. BTW: I'm assuming that you EmpTime app is a clone of the Labor Report app.
https://www.ibm.com/support/pages/maximo-76designer-431-report-development-guide
Principal Consultant
COSOL
email:
craig.kokay@cosol.global#IBMChampion
