Hi Kiran,
Are you referrting to integration user like MXINTADM?
(If your question to rest/update user password. you can do via User application)
To Update the password of integration end point, like REST API, Webservice., then it must be done on external/thrid party system which calls the Maximo API./Webservice.
It also depends on type of authentication.For example,, if using a MAXAUTH header, the username:password must be encoded in Base 64 format.
There are also other type of authtications discussed here.
REST API : OSLC (NextGenRest) API Authentication in IBM Maximo
Webservice: MaximoDev - Maximo Web Services tutorial
Configuring Maximo Authentication
Thanks!
Sankar
Sankar Ganesh V S
DXC Technology
