  • 1.  How to upload Job Plan Tasks using MxLoader
    Posted 04-21-2026 08:39
    Hello everyone,
    Could anyone please explain whether it is possible to upload Job Plan Tasks into IBM Maximo using MxLoader?
    For example, if I have around 300 Job Plans, and each Job Plan contains 5–10 tasks. All this information (Job Plan number, task sequence, description.) is already properly structured in an Excel file.
    • Can Job Plan Tasks be uploaded through MxLoader? & if yes, How can it be?
    • If no, what is the recommended alternative approach for mass creation of Job Plan Tasks?
    Any guidance or practical examples would be really appreciated. Thanks!
    Kind regards,
    Burhan
    Burhan Khan
    Andritz Hydro
  • 2.  RE: How to upload Job Plan Tasks using MxLoader
    Posted 04-21-2026 11:53
    Yes, it is possible to upload Job Plan Tasks into IBM Maximo using MxLoader, and this is one of the most common and effective ways to handle mass creation of Job Plans with their tasks (especially for 300+ Job Plans with 5–10 tasks each).
    How to Do It with MxLoaderMxLoader uses a custom object structure called MXL_JOBPLAN (included in the standard MxLoader templates) that supports both the Job Plan header and its child records, including JOBTASK (Job Plan Tasks).
    Recommended Step-by-Step Approach
    1. Prepare your Excel sheet properly
      • Use the JobPlans template from MxLoader (or create a new sheet pointing to the MXL_JOBPLAN object structure).
      • The first set of columns will be for the JOBPLAN object (e.g., JOBPLAN, DESCRIPTION, ORGID, SITEID, STATUS (usually set to DRAFT or PNDREV during initial load), etc.).
      • For tasks, add columns prefixed with the child object, typically like this:
        • JOBTASK.TASKID or JOBTASK.JPTASK (task identifier)
        • JOBTASK.SEQUENCE (important for ordering – usually 10, 20, 30…)
        • JOBTASK.DESCRIPTION
        • JOBTASK.LONGDESCRIPTION (if needed)
        • Other optional fields: JOBTASK.ESTIMATEDDURATION, JOBTASK.JOBPLAN, etc.
      In your Excel, structure it so that each Job Plan header row is followed by its related task rows (MxLoader handles parent-child relationships via the object structure).
    2. Key Tips for Success
      • Load in two passes if needed: First load only the Job Plan headers (with minimal data), then load the tasks in a second sheet or the same sheet with child rows. Many people do it in one go successfully.
      • Job Plans must be in DRAFT or PNDREV status when adding/updating tasks. You can activate them afterward.
      • Make sure the MXL_JOBPLAN object structure in Maximo includes the JOBTASK object as a child (check in the Object Structures application).
      • Use the Query function in MxLoader first on a manually created sample Job Plan (with tasks) to see the exact column format and structure that works in your environment.
      • Watch out for hidden/non-printable characters in descriptions (common issue that causes load failures).
      • For long descriptions with formatting, convert Excel formatting to HTML if required.
    3. Common Columns Example (simplified):
      • JOBPLAN, DESCRIPTION, ORGID, SITEID, STATUS
      • JOBTASK.SEQUENCE, JOBTASK.DESCRIPTION, JOBTASK.ESTIMATEDDURATION ...
    After loading, go to the Job Plans application, search for your plans, revise if needed, and Activate them.
    If You Run Into IssuesCommon errors include:
    • "Action ADD is not allowed on object JOBTASK" → Usually fixed by ensuring JOBTASK is properly added to the object structure and the Job Plan is in Draft/PNDREV status.
    • Data not appearing → Check row ordering in Excel and that parent-child linking is correct.
    Cheers! Hope this helps ... if not, maybe it will spark a lively discussion.
    Charlie
    CHARLES LAMB
    Bay Area Rapid Transit
Featured Podcast
Watch the Podcast
Watch the latest episode
