  • 1.  Hyperlink to Submit a Service Request Work Center
    Posted 02-08-2023 11:07
    We are on Maximo 7.6.1.3.  We are implementing the "Submit a Service Request" Work Center.
    In the past we have sent out hyperlinks in communication templates to the technician working the ticket
    https://<SERVER>:443/maximo/ui/maximo.jsp?event=loadapp&value=sr&uniqueid=:ticketuid
    but this obviously takes you to the Service Desk --> Service Request application
    Is it possible to link directly to self-service "Submit a Service Request" Work Center and open a specific Service Request?
    #WorkCenters
    Eric Burkland
    San Diego County Water Authority
  • 2.  RE: Hyperlink to Submit a Service Request Work Center
    Posted 02-09-2023 01:08
    You need to point to maximo-x application for any Work Center in the URL. For example, this URL will open Submit A Service Request Work Center -
    https://<server:port>maximo-x/#/selfservice
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: Hyperlink to Submit a Service Request Work Center
    Best Answer
    Posted 02-10-2023 08:18
    So long as the ticket remains active, you can hyperlink directly to it with the following URL:
    https://[host]/maximo-x/?uid=:ticketuid#/selfservice/active/detail
    If the ticket is no longer active, it can be referenced like this:
    https://[host]/maximo-x/?uid=:ticketuid#/selfservice/history/detail
    Obviously email doesn't give you the luxury of knowing what the status of the ticket will be when the user clicks the link. So you can either:
    1. Assume active - if the ticket is no longer active then the user will see a blank page. You'll likely need to train them on that possibility and what to do.
    2. Establish a proxy URL that can take the "ticketuid" as a parameter, look up the status of the ticket, and forward the user to the proper address.
    Hope this helps,
    Alex Walter
    A3J Group, LLC
  • 4.  RE: Hyperlink to Submit a Service Request Work Center
    Posted 02-10-2023 11:10
    Thanks for your help.
    Cheers,
    Eric
    Eric Burkland
