  • 1.  IBM DB2 Errors
    Posted 03-31-2026 01:47
    Good day, dear experts!
    For some time now, I've been seeing an error in the Windows event log, albeit quite rarely. How can I avoid it in the future and fix it now?
    From the perspective of IBM Maximo users, they don't experience any inconvenience.
    The error looks like this:
    2026-03-31-00.38.01.605000 Instance:CTGINST1 Node:000
    PID:1772(db2syscs.exe) TID:19192 Appid:*LOCAL.CTGINST1.260330213816
    data management sqldDataFetch Probe:6550 Database:VR_PRD
    ADM5595E Inconsistent index data was detected for table "SYSIBM "."SYSCOLDIST".
    Run "INSPECT CHECK TABLE NAME
    "SYSCOLDIST" SCHEMA "SYSIBM " INDEXDATA RESULTS KEEP "SYSCOLDIST"_resfile.out" on the failed node and report this error to DB2 Support.
    Sergey Melnikov
    RusNet
  • 2.  RE: IBM DB2 Errors
    Posted 04-07-2026 10:01
    Hello Sergey ,
    The error looks like the data inconsistency with respect to existing index.
    1. You can give a fresh full system restart.
    2. You can run below and see whether there is any index inconsistency.
    INSPECT CHECK TABLE NAME "SYSCOLDIST" SCHEMA "SYSIBM" INDEXDATA  RESULTS KEEP SYSCOLDIST_resfile.out
    3. You may also try to rebuild the index.
    Tinnokesh AP
  • 3.  RE: IBM DB2 Errors
    Posted 05-25-2026 15:36
    Hello!
    Thank you so much for your reply!
    I tried rebuilding the indexes this way, but it's a system-wide operation, and those commands don't work.
    I also tried running db2dart, but that command requires a service password.
    Sergey Melnikov
    RusNet
