  • 1.  Import Application Message
    Posted 09-06-2024 10:04
    Dears kindly help why i couldn't change an application import operation
    syn to another and attached message has appeared.
    nasr buzaid
    eni
  • 2.  RE: Import Application Message
    Posted 09-06-2024 17:32
    Hi @nasr buzaid!
    If you try to change the operation field directly, that error message appears.
    But if you maximize the import section, you will be able to change the action
  • 3.  RE: Import Application Message
    Posted 09-07-2024 04:08
    Many thank @Martin Fabra the issue solved
    nasr buzaid
    eni
