  • 1.  Inspection Form Limits
    Posted 06-18-2026 08:46
    I'm wondering if anyone currently uses EzMaxMobile, if they provide limits for end users completing inspections?
    For example, if there is a breaker inspection with gas-pressure gauge meter, if it'd display the condition monitoring limits i.e. upper limit of 90 and lower limit of 72? So the inspector would know if what they were entering was within the limits?
    Hopefully, that makes sense. Thank you!
    Stephanie Olson
    Minnesota Power
  • 2.  RE: Inspection Form Limits
    Posted 06-19-2026 14:02
    Hi Stephanie,
    Good to see you again :)
    This has been implemented as an enhancement for multiple clients. Please feel free to submit a support ticket, and we'll be happy to assist you further!
    Ram Raman
    Product Support Lead
  • 3.  RE: Inspection Form Limits
    Posted 06-22-2026 09:24
    Hi Ram,
    Thank you! We are more looking to see how other customers use it vs. starting an implementation. Do you know of anyone that would be willing to meet briefly to give us a high-level overview of how it works on their inspection forms?
    Thanks again!
    Stephanie Olson
    Minnesota Power
  • 4.  RE: Inspection Form Limits
    Posted 07-01-2026 16:35
    Hi Stephanie,
    I apologize for the delay.
    While I'm unable to speak on behalf of our clients or share their specific implementation details, if you submit a support ticket, we would be happy to review examples of how this functionality has been implemented in other environments.
    We can also coordinate with our Implementation Team to provide a high-level overview of common use cases and approaches that clients have taken when leveraging this functionality.
    Ram Raman
  • 5.  RE: Inspection Form Limits
    Posted 07-02-2026 08:35
    Hi Stephanie,
    What I've seen some organizations do is include the acceptable limits directly in the inspection question's description. In your case, however, this may not be practical. For example, with breaker inspections, different breakers may have different acceptable ranges. It sounds like you're trying to leverage Maximo data, such as the asset's Condition Monitoring points, to provide those limits dynamically.
    While including the limits in the inspection question can work for some customers, there are also reasons why others choose not to. Many organizations don't want inspectors to simply enter a value that falls within the displayed range. Instead, they prefer inspectors to record the actual measured value and rely on Maximo's built-in condition monitoring and inspection automation to determine whether the reading falls outside the defined thresholds and automatically generate the appropriate follow-up work order or notification. This helps ensure the process remains objective and that corrective actions are driven by the system rather than by the inspector's interpretation.
    Since you're using EZMaxMobile, there may be a way to retrieve and display that information within the inspection form, although I'm not certain. As Ram suggested, reaching out to Naviam (InterPro) Support would be a good approach, as they may already have a recommended solution or best practice.
    Mike
    Michael Marsonet
    MRM-EAM Consulting Inc.
  • 6.  RE: Inspection Form Limits
    Posted 07-07-2026 11:51
    Hi Mike,
    Thank you for your comments. That is a good point on providing the limits on the actual inspection. We do have the limits set-up so, I'll have to look into Maximo's built-in condition monitoring and inspection automation with our Maximo team.
    Again, thank you,
    Stephanie
    Stephanie Olson
    Minnesota Power
  • 7.  RE: Inspection Form Limits
    Posted 15 days ago
    Hi Stephanie,
    Although I am not qualified to answer EzMaxMobile-related questions, as I have never supported the tool. I would like to offer a recommendation.
    Your question is multi-layered and complex. Can I make a suggestion? Use your unique business use case to frame your requirements to establish the baseline required to determine whether the solution you have implemented meets your business requirements or requires enhancements to align with your business case.
    Are you familiar with
    IBM Maximo Labs?
    1.    IBM Maximo Labs cover a broad spectrum of topics and are structured to build the foundation required to understand your unique business case and define the requirements to implement the right solution from the IBM Maximo portfolio.
    2.    IBM Maximo Labs are version-specific.
    3.    IBM Maximo Labs provide practical guides and checklists that ensure you enforce E2E best practices throughout your implementation's SDLC lifecycle.
    Building on Mike's excellent points about process objectivity, leveraging Maximo's built-in automation is a highly effective way to handle this without biasing the inspector's input or unintentionally implementing misaligned configuration that works for a different organization's use case but is misaligned with defining your unique use case.
    As a practical, step-by-step blueprint, use the public IBM Maximo Hands-On Labs Catalog. Specifically, the Maximo Health & Predict lab modules provide comprehensive exercises on:
    • Condition Monitoring Configuration: Mapping meter data directly to assets.
    • Threshold & Limit Logic: Defining upper/lower limits (like your 72–90 gauge thresholds) in the system backend.
    • Automated Work Queues: Triggering automatic follow-up actions, notifications, or corrective work orders the moment a recorded inspection value falls outside the normal operating zone.
    By managing the limits via Maximo's core condition monitoring engine rather than hardcoding them into a mobile form UI, you maintain data integrity while ensuring critical assets automatically get the immediate engineering attention they need. The documentation and guides are completely open-source and can be reviewed at ibm.github.io/maximo-labs/. I have attached PDF examples of the Build and Test Guides for MAS v8.11.
    To answer your question, you first need to clearly understand the preceding foundational concept. The foundation above will clarify how you frame your question, as not all Inspections in Maximo are the same. If your question is specifically related to the Inspections Role-based application versus the Technician Mobile application, it's important to clarify the distinct requirements for each implementation to mitigate risks and ensure use case alignment.
    Hope this gives your technical team a solid head start on exploring the built-in capabilities!
    Best regards,
    Fredrick Ndwaru
    Perpetual Ignition
