  • 1.  Inspection Forms under review
    Posted 01-29-2026 08:58
    Hello Maximo Community,
    Is it possible, while the inspector is conducting the inspection, while he is completing the form the status of the inspection result is changed to REVIEW. Then another inspector will open the inspection result under review, verify, edit if needed and complete it. Knowing that our Maximo environment is 7.6.1.2 and work center 7.6.0.4
    Thank you!
    #WorkCenters
    Oumayma Azouz
    AtkinsRealis
  • 2.  RE: Inspection Forms under review
    Posted 01-29-2026 13:15
    You could try to customize the work center but it's a very tedious task and won't be relevant once you get to MAS. In MAS there is a new UI framework that Inspections was rewritten for and they added a lot of features, including an optional review process (enabling system property mxe.mobile.inspection.features.enablereview).
    If you have Maximo Application Suite entitlements, you are able to deploy the Maximo Mobile applications to your 7.6 instance which would enable this feature. However, on 7.6.1.2 the latest version of Maximo Mobile supported was 8.8 which is no longer supported. If you are potentially considering going to 7.6.1.3 you would be able to deploy Maximo Mobile 9.0 which is still supported. Again, it does require MAS entitlements though to get access to the package.
  • 3.  RE: Inspection Forms under review
    Posted 01-29-2026 22:34
    Thank you so much
    Oumayma Azouz
    AtkinsRealis
