  • 1.  Install Work Center (maximo-x) for the first time on 7.6.1.2
    Posted 07-29-2022 14:02
    Hello. We are on 7.6.1.2 and wanted to look at Work Center. I'm able to go to https://server/maximo-x/ but it redirects to the Maximo Start Center. With 7.6.1.2, has the configuration changed from earlier versions of Maximo (e.g. 7.6.0.8). I am reading conflicting information about a Work Center field in Security Group on earlier versions, but I do not see it in 7.6.1.2 . The only promising tutorial I've seen is this Pam Denny video on YouTube - Maximo 7608+ Setting Security Access for Work Centers .
    Does anyone know if this is the right steps for Maximo 7.6.1.2?
    #WorkCenters
    sun kim
    j. paul getty trust
  • 2.  RE: Install Work Center (maximo-x) for the first time on 7.6.1.2
    Posted 07-29-2022 14:37
    I'm following Pam Denny's YouTube video
    https://www.youtube.com/watch?v=DqJcxyUOhlE
    I set up appServerSecurity is true and configured web.xml and config.json properly (I think)
    https://www.ibm.com/support/pages/deploying-maximo-work-centers-ldap-and-non-ldap
    I gave read access to the MXAPIKPIMAIN in Security Groups > Object Structures
    I am able to log into maximo-x by logging into maximo, then being redirected to maximo-x because my user is set up to be business analyst. I get some of the KPI loaded, but I get 400 error saying I don't have READ permission
    https://server.getty.edu/maximo/oslc/os/mxapikpimain?lean=1&collectioncount=1&oslc.select=kpiname%2Ckpivalue%2Clastkpivalue%2Cdescription%2Ccautionmin%2Ccautionmax%2Cformat%2Cdescription_longdescription&oslc.pageSize=50&oslc.where=kpiname=%22EMWNODOWN%22&addlocalizedrep=1&addid=1&querylocalized=1
    {"Error":{"extendedError":{"moreInfo":{"href":"https:\/\/server.getty.edu:443\/maximo\/oslc\/error\/messages\/BMXAA0024E"}},"reasonCode":"BMXAA0024E","message":"BMXAA0024E - The action READ is not allowed on object KPIMAIN. Verify the business rules for the object and define the appropriate action for the object.","statusCode":"400"}}
    sun kim
    j. paul getty trust
  • 3.  RE: Install Work Center (maximo-x) for the first time on 7.6.1.2
    Posted 07-30-2022 00:45
    I got it figured out and installed the Guest Self Service Service Request module as well.
    sun kim
  • 4.  RE: Install Work Center (maximo-x) for the first time on 7.6.1.2
    Posted 08-12-2022 08:30
    The very basic you need to do once u have installed work center is to add the user to a role . Business Analyst or Technician for u to start seeing the work centers .
    Thanks & Regards
    Venkat
