  • 1.  Integration using HTTP handler for end point
    Posted 02-16-2025 08:25
    I'm trying to send a post request from maxim to another Maximo (test server), the end goal is to integrate with MS dynamics, but I want to check configuration first and analyze the response (where and how I'll get the response data), but it fails every time and I cannot identify the problem
    anyone has a previous experience with this kind of integration
    #IoT
    Abdelrahman Abbas
    RATPdev
  • 2.  RE: Integration using HTTP handler for end point
    Posted 02-16-2025 13:39
    Maybe I'm remembering wrong but to use Business Central webservices you need to authenticate via OAuth.
    Diego Visentin
    Tempestive S.p.A.
  • 3.  RE: Integration using HTTP handler for end point
    Posted 02-17-2025 05:12
    thank you
    would you clarify more ?
    Abdelrahman Abbas
    RATPdev
  • 4.  RE: Integration using HTTP handler for end point
    Posted 02-17-2025 05:45
    You can find info in docs of v7.6.1.3 and in technotes like this: How to use OAuth2 authentication on outbound integration
    Also, @Biplab Choudhury wrote about it: (1) Maximo 7613 OAuth Authentication Support | LinkedIn
    Diego Visentin
    Tempestive S.p.A.
  • 5.  RE: Integration using HTTP handler for end point
    Posted 02-17-2025 07:57
    unfortunately, I found the TPAE is 7612 which is not valid for this configuration
    thank you so much for your support
    Abdelrahman Abbas
    RATPdev
  • 6.  RE: Integration using HTTP handler for end point
    Posted 03-05-2025 09:50
    Couple of observations.  If you're sending a POST to Maximo, then the tag cannot be "Publish".  It needs to be "Sync", so you'll need to add a customization to your outbound integration to change this.
    If you're POSTing XML to Maximo, then the content type needs to be "text/xml", not "application/xm".
    The unauthorized error you're receiving is probably because of improper authentication.  For authenticating, you need to pass a header of "MAXAUTH" and the value is a base64-encoded value "username:password".  Also, I would remove the apikey from the header since you're using username/password.
    Good luck!
    Carlos Marin
    Sharptree
    Senior Integration Developer
