  • 1.  "Invalid map configuration file" error configuring MAS 9.0 Spatial with ESRI web map
    Posted 10-23-2025 17:01
      |   view attached
    I am configuring MAS 9.0 Spatial. I want to use an ESRI web map with oauth authentication. Map Manager saves the configuration without any errors, but when I click on the Map tab in "Work Order Tracking" or "Assets", I get a popup error that says "Invalid map configuration file". The attached stack trace is in the log, followed by the DEBUG message "PlussMapManager - WebMap is not enabled". This environment was upgraded from a working 7.6.1.3 environment that had Spatial using ESRI map services. Even though the error in the stack trace indicates a missing PLUSSFEATURECLASS attribute, the WORKORDER table and the other GIS-enabled tables all have the attribute.
    What could be causing this error?
    #Spatial
    Theo Pozzy
    OneGas
    Attachment(s)
  • 2.  RE: "Invalid map configuration file" error configuring MAS 9.0 Spatial with ESRI web map
    Posted 10-24-2025 08:47
    Hi Theo,
    I believe this may be your issue https://www.ibm.com/mysupport/s/defect/aCIKe000000g3KhOAI/dt433461?language=en_US as reported by IBM. It was recently updated and closed which means a fix is available. You may want to open an IBM case to get clarity from IBM what patch level the fix is included.
    Mike
    Michael Marsonet
    MRM-EAM Consulting Inc.
