Maximo Business News
Inventory ABC, ROP and EOQ Reports
  • 1.  Inventory ABC, ROP and EOQ Reports
    Posted 07-25-2024 08:17
    Thanks Andrew Jeffrey for the post on the changes to these reports. The full post is here in the IBM Community and details are copied below:
    There are two versions of these reports, the ones you should use are the ones with Transaction Date Analysis in the title. The three reports Inventory EOQ Analysis, Inventory ROP Analysis and Inventory ABC Analysis should not be used and should be removed - IBM have decided not to delete these old reports or fix any issues in them. They will continue to fix issues in the reports with Transaction Date Analysis in the title.
    IBM have published this Tech Note - https://www.ibm.com/support/pages/what-are-eoq-rop-and-abc-transdate-reports-used
    I am still trying to get an answer on plans to reinstate the functionality to update the ABC, EOQ, and ROP values, this was removed in 7.6.1.3. I raised the IBM Idea for this, I just checked it has 25 votes and is marked as Future Consideration, I am sure we can get it to over 100 if you care to help - https://ideas.ibm.com/ideas/MASM-I-987
    I never like to see existing functionality disappear from Maximo, it is impossible to know which client uses the functionality and suddenly finds it missing when they upgrade.
    Regards - Andrew
    Andrew Jeffery
    Maximo SME
    ZNAPZ b.v
    Barnstaple
    0777 1847873
    Vote if you can at https://ideas.ibm.com/ideas/MASM-I-987
    IBM Champion 2024
