Is it not possible to query data sources using the WHERE clause on mobile devices using the Maximo mobile app?
  • 1.  Is it not possible to query data sources using the WHERE clause on mobile devices using the Maximo mobile app?
    Posted 04-27-2026 22:36
    Hello.
    I am currently developing the Maximo mobile app (MAF App).
    I created the page controller and executed the relevant method, but it seems that the query is not working with the WHERE clause.
    The functionality I want is to retrieve both the fromdate and todate for the 'tagstartdate' column in a single query to retrieve data between the fromdate and todate.
    It appears that using setqbe only satisfies one of the two conditions: querying by fromdate or querying by todate. I would appreciate your suggestions on how to resolve this.
    Also, could you explain how the web and mobile differ so that a feature that works on the web does not work on mobile devices?
    Thank you.
       async testWorkSearch(e){
            const fromdate = this.dateFormat(new Date());
            const todate = this.dateFormat(new Date());
            const dateWhere = `targetstartdate>="${fromdate}" and targetstartdate<="${todate}"`;
            await this.listDS.load({
                noCache: true,
                where: dateWhere
    GeunYoung Ahn
    Visionic
  • 2.  RE: Is it not possible to query data sources using the WHERE clause on mobile devices using the Maximo mobile app?
    Posted 04-28-2026 12:30
    GYA,
    If you need guaranteed server hits, consider mobile-server-search="true" on the datasource (limits to page size) + proper QBE. But this reduces offline capability.
    The mobile-server-search="true" option (introduced/enhanced in Maximo Mobile 9.0) is specifically designed for cases like yours - where you need dynamic, runtime server-side queries (e.g., a custom date range WHERE clause that isn't feasible with pre-synced local data or simple QBE).
    You add that option via a data source override in your page's XML definition (NOT directly on the main <maximo-datasource> in most cases).
    Here is the XML:
    <maximo-datasource id="listDS"
                       object-structure="..."
                       saved-query="..."
                       pre-load="false"   <!-- often used with this feature -->
        <!-- your schema attributes here -->
        <!-- Override for server-side behavior -->
        <maximo-datasource-override id="serverSearch"
                                    page-size="20" />   <!-- adjust as needed; common values 5–20 -->
    </maximo-datasource>
    Then run your script from Maximo as you have it written.
    - the framework will now route the query to the Maximo server instead of the local SQLite DB (when the device is online).
    Play with it!
    Hope this helps
    CHARLES LAMB
    Bay Area Rapid Transit
  • 3.  RE: Is it not possible to query data sources using the WHERE clause on mobile devices using the Maximo mobile app?
    Posted 05-13-2026 09:44
    Thank you for your reply.
    I will try to proceed as you instructed.😀
    GeunYoung Ahn
    Visionic
