Is it possible to increase the Batch Inspection size past 50?
  • 1.  Is it possible to increase the Batch Inspection size past 50?
    Posted 11-11-2024 13:15
    We are on version 7.6 of Maximo and started doing inspections.
    At first, we did complicated ones but if it branches and you answer one way and then change your answer and answer another it now has the data for both.  So reports and things need to understand each inspection rather than being generic.  So we decided to lean into the Routes and make smaller generic inspections and have it run over and over for the different assets.  This worked ok for the pilot but now we have run into an odd limit that I am hoping someone knows how to overcome.
    When you do a batch inspection it only pulls in the first 50 inspections on a work order and handles only those without telling the user that they haven't completed everything.  Does anyone know how to adjust the number of inspections that it will do at once?  We have an example with 90 but I can see this getting up over 100 easily.
    #ServiceProvider
    Brad Delong
    WDW
