  • 1.  Is there any way to set a default value for the memo field in the Complete Workflow Assignment dialog?
    Posted 03-31-2023 02:23
    Each time user clicks the route workflow button in the application, Maximo will automatically set a value for the memo field like "Approved".
    Any help would be appreciated, thank you.
    [Acey] [Nguyen]
    [NGS]
  • 2.  RE: Is there any way to set a default value for the memo field in the Complete Workflow Assignment dialog?
    Posted 04-01-2023 11:20
    Hello - Go to Database Configuration and Open COMPLETEWF. Go to Attribute > Memo and set the default value as Approved. Perform ConfigDB and then test the WF.
    One done, Approved will set in Memo
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: Is there any way to set a default value for the memo field in the Complete Workflow Assignment dialog?
    Posted 04-09-2023 11:23
    Thank Prashant Sharma for your suggestion.
    I missed a key point, my expectation is setting a value for the memo field in the complete workflow assignment dialog when a specific user clicks route workflow.
    [Acey] [Nguyen]
    [NGS]
