Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
  • 1.  Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-12-2021 14:49
    Edited by Christopher Winston 11-12-2021 15:03
    MXLoader - I want to be able to add the Classification to the Job Plan as I load and update job plans. I cant get the field do either come down in a query or upload to the field.
    I have the following relationships in the obj stucture.
    Object Parent Object Object Location Path Relationship Object Order User Defined Exclude Attributes Mode
    JOBPLAN JOBPLAN 1 Y N
    CLASSSTRUCTURE JOBPLAN JOBPLAN/CLASSSTRUCTURE CLASSSTRUCTURE 1 Y N
    JOBTASK JOBPLAN JOBPLAN/JOBTASK JOBTASK 2 Y N
    JOBLABOR JOBPLAN JOBPLAN/JOBLABOR JOBLABOR 3 Y N
    JOBMATERIAL JOBPLAN JOBPLAN/JOBMATERIAL JOBMATERIAL 4 Y N
    Kimberly Garcia
    Caesars Entertainment
  • 2.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-15-2021 02:15
    Edited by Manuel Guyot 04-30-2026 08:44
    If I understand well you want to add "DEFAULTWOCLASS" in the Object Structure for JOBPLAN, this is a Non-persistent field and you have to include it to the Object Structure. To do so, in your Object Structure, you have to open Select Action and choose Exclude/Include Fields, then open the Non-Persistent Fields and tick the "DEFAULTWOCLASS" to include it.
    MG
  • 3.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-15-2021 12:51
    Thanks so much, this worked as far as brining the Class ID into MXloader. But not the Hierarchy path.
    Mxloader fields are:
    JPNUM ORGID SITEID PLUSCREVNUM STATUS JPDURATION DESCRIPTION CLASSSTRUCTURE.CLASSSTRUCTUREID CLASSSTRUCTURE.
    HIERARCHYPATH
    COTW-01M-JOL CET JOL 2 ACTIVE 1.0 Monthly, Condensing Water Strainers 1622
    Kimberly Garcia
  • 4.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-15-2021 13:01
      |   view attached
    Hey Kimberly,
    Looks like you may need to check the "Include" box on the MXL_JOBPLAN object structure. Please see the attached image.
    Matt McGuire
    Aquitas Solutions
    Attachment(s)
    docx
    Include_Exclude Image.docx   140 KB 1 version
  • 5.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-16-2021 17:09
    I dont have the that option in the non persistent fields.
    I only have the six below.
    Is there a process to add them?
    Kimberly Garcia
  • 6.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-16-2021 17:37
    I think you will need to add CLASSSTRUCTURE under the Source Objects for MXL_JOBPLAN, first.
    Then, you should be able to see the HIERARCHYPATH
    Stevie
    Stevie Holloway
    Tufts University
  • 7.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-17-2021 11:24
    Thanks so much for the clear instructions. I made a rookie mistake and forgot to first select classstructure before looking for the non persistent fields.
    With your screen shot, I was able to see and select them, and they now come down to my mxloader sheet.
    Thanks so much for the assistance!
    Kimberly Garcia
  • 8.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-17-2021 11:58
    I'm happy to help.
    Stevie
    Stevie Holloway
    Tufts University
  • 9.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 03-19-2024 11:53
    It's crucial to ensure that "DEFAULTWOCLASS" is properly integrated into the Object Structure for JOBPLAN. As a Non-persistent field, its inclusion is essential for accurate data handling.
    Sunnyle Khan
    google
  • 10.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-15-2021 09:07
    Hi Kimberly,
    Similar to what Manuel stated, you'll want to open your object structure, open the Exclude/Include dialog, navigate to the Non-persistent tab and select "Include" next to HIERARCHYPATH. On your load sheet I recommend adding CLASSSTRUCTURE.HIERARCHYPATH and CLASSSTRUCTURE.CLASSIFICATIONID.
    Matt McGuire
    Aquitas Solutions
  • 11.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-15-2021 10:42
    What does your MxLoader sheet look like? I don't think you can go down too many levels with MxLoader. You might have to do separate queries with separate loads?
    Stevie
    Stevie Holloway
    Tufts University
  • 12.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-15-2021 11:48
    Edited by Manuel Guyot 04-30-2026 08:45
    Hi Stevie, "DEFAULTWOCLASS" is at the same level as JOBPLAN, it is just a Non-Persistent field that is not included.
    MG
  • 13.  RE: Job Plan, CLASSSTRUCTURE.HIERARCHYPATH
    Posted 11-15-2021 12:30
    Hey Manuel,
    DEFAULTWOCLASS refers to the WOCLASS (ie activity, release, change, or workorder). I believe Kimberly will need to use attributes from the CLASSSTRUCTURE object she's added to her OS.
    Matt McGuire
    Aquitas Solutions
