  • 1.  Limit when Exporting Records to Excel in PM Application
    Posted 05-29-2025 19:52
    Hi everyone,
    I need some help to solve an issue that's taking me quite some time and I can't find the root cause.
    In the PM application, I can see 1876 records in the list view. When I click "Export" to send them to Excel, I only get 400 records in the file.
    I have another application, cloned from PM for a different department, and when I export, it works as expected-if there are 2000, 3000 records, all are exported correctly. This also works fine in other applications, but in PM it's always 400.
    I checked that both applications use the same beans, and reviewing the XML I didn't find any reason for this behavior. I also checked the properties files, but since reports work well, I ruled that out.
    Where could this limit be coming from? Can anyone point me in the right direction?
    Thank you in advance!
  • 2.  RE: Limit when Exporting Records to Excel in PM Application
    Posted 06-06-2025 05:45
    Are you using Export application or the Download to excel option?
    Niv Geo
  • 3.  RE: Limit when Exporting Records to Excel in PM Application
    Posted 06-09-2025 11:58
    Check in your system properties for entries that start with "mxe.db.fetchresult"
    Example
    (This sets the default value for all the Maixmo Objects)
    Property Name: mxe.db.fetchResultStopLimit
    Description: Default fetch stop limit for the objects.
    Current Value: 5000
    (This sets the value for fetch limit on PM. It will over-ride the default for objects.)
    Property Name: mxe.db.fetchResultStopLimit.PM
    Description: Default fetch stop limit for the PM object
    Current Value: 8000
    IBM artricle:
    BMXAA7387E - While Attempting to Retrieve 5001 of MULTIASSETLOCCI
    https://www.ibm.com/support/pages/bmxaa7387e-while-attempting-retrieve-5001-multiassetlocci
    Christopher Barefield
    Bechtel
  • 4.  RE: Limit when Exporting Records to Excel in PM Application
    Posted 06-12-2025 08:44
    If the fetchResultStopLimit is stopping the operation then there should be a WARN entry in the logs.
    It is always worth checking the logs for clues in situations like this
    mark robbins
    Cohesive
