  • 1.  Map in Manage v9
    Posted 02-16-2025 13:44
    Edited by Diego Visentin 02-16-2025 13:46
    In Manage v9 support for Google/Bing Maps is deprecated (link).
    So I am trying to use Open Street as a provider, but the result is disappointing. I can see the mapping in the Map tab, but the object seems to be hidden (seems to be an overlay bug) and the tools on the map have disappeared. I have tried to enable them by configuring map tools on map-admin app, but without success.
    Has anyone been able to use this provider without regretting their previous use of Google Maps? Or am I just missing something?
    PS:
    I am very familiar with Maximo Spatial, so I trust that using ESRI product/services everything works great, but often customers just need to see their assets/workorders projected on a map.
  • 2.  RE: Map in Manage v9
    Posted 02-17-2025 08:34
    Diego,
    I believe you are referring to the layers not being displayed when the map is opened? If you open the browser developer tools you will likely have errors similar to "Content-Security-Policy: The page's settings blocked the loading of a resource at" and the following technote https://www.ibm.com/support/pages/content-security-policy-blocked-load-map-resources will address your issue. You will also find this documented in the Manage Continuous Delivery documentation (Not where you would expect it in the Spatial document but rather in the Health and Predict)  https://www.ibm.com/docs/en/mhmpmh-and-p-u/continuous-delivery?topic=started-getting-application-administrators
    Mike
    Michael Marsonet
    MRM-EAM Consulting Inc.
  • 3.  RE: Map in Manage v9
    Posted 02-18-2025 09:53
    Edited by Ken Thomson 02-18-2025 09:54
    Diego / Michael,
    I had this exact issue with one of the versions of MAS, I think it was 8.11 in this case the ESRI base map was being 'blocked', and it required an update to the property mxe.sec.header.Content_Security_Policy, exactly as described in the technote, I had to add *.arcgis.com to 'see'.
    It was 'strange' in that the features appeared to be there but did not display, which I guess was related to images being blocked.
    This seems to have been resolved in 9 though, as I no longer require it to be declared in that property, and maps are rendering correctly.
    All that said, I have not attempted to use Open Street Map (yet).
    Good Luck
    Ken
    Ken Thomson
    Aquitas Solutions
  • 4.  RE: Map in Manage v9
    Posted 02-18-2025 10:18
    Ken,
    thank you for your suggestion.
    We are trying on v9.0.8 and v9.1.0-pre.stable-9630 and we have already set the mxe.sec.header.Content_Security_Policy property (in fact the base map can be seen, it is the Maximo object that disappears).
    In the IBM forum @Steven Shull kindly replied to me that it is a bug (link) that will be addressed by a future release.
    Diego Visentin
    Tempestive S.p.A.
