Maps not loading – Blank screen with green dot in Mas 9.1.2
  • 1.  Maps not loading – Blank screen with green dot in Mas 9.1.2
    Posted 09-23-2025 19:20
    I'm facing an issue where the Maps view in Maximo is not loading correctly. The screen only shows a blank view with a green dot in the center. This issue started appearing after the MAS 9.1.2 upgrade.
    I have already followed this IBM documentation: How to repair the visibility of Maps in MAS 9.1, and I can see that attribute length is 2000.As per the documentation the issue is with 9.1 but this is 9.1.2 ideally issue should resolved.
    Has anyone else faced this issue or found a solution? Any help would be greatly appreciated.
    Thank you!
    jack jack
    jack
