  • 1.  MAS Cloud Attachment Access for PowerBI Inspection Image Dashboard
    Posted 5 days ago
    We are brainstorming a PowerBI dashboard that would display image attachments from Maximo inspections.
    We know that the inspection from image attachments involved the DOCLINKS/DOCINFOR/INSPFIELDRESULT tables and that would be the metadata we need to link the attachment on the inspection to the DOCLINKS location. We are a cloud based customer and the images are stored in AWS
    Has anyone ever done anything similar?
    Is there a way to grant read only access to the S3 bucket for these attachments?
    Can we use a product like CloudFront to enable such an integration?
    If we cannot directly hit the S3 for these attachments, do you have recommendations on how to enable this?
    Are there any security concerns with this?
    I've already figured out how to query in DB2 for the data but need to solution how to pull the attachments to a PowerBI report when our attachments are in an S3 bucket.
    select
    ir.resultnum,
    ir.inspformnum,
    ir.revision,
    ir.status as inspection_status,
    ir.createdate as inspection_createdate,
    ir.createdby as inspection_createdby,
    p_ir_createdby.displayname as inspection_createdby_displayname,
    ir.asset,
    a.description as asset_description,
    ir.location,
    l.description as location_description,
    ir.referenceobject,
    ir.referenceobjectid,
    ir.siteid,
    iq.inspquestionnum,
    iq.description as question_description,
    iq.sequence as question_sequence,
    ifld.inspfieldnum,
    ifld.description as field_description,
    ifld.fieldtype,
    ifld.sequence as field_sequence,
    ifr.inspfieldresultid,
    ifr.inspfieldresultnum,
    ifr.txtresponse,
    ifr.numresponse,
    ifr.enteredby,
    p_ifr_enteredby.displayname as enteredby_displayname,
    ifr.entereddate,
    dl.doclinksid,
    dl.ownertable,
    dl.ownerid,
    dl.document as doclinks_document,
    dl.doctype as doclinks_doctype,
    dl.createdate as doclink_createdate,
    dl.changeby as doclink_changeby,
    p_dl_changeby.displayname as doclink_changeby_displayname,
    di.docinfoid,
    di.document as docinfo_document,
    di.description as doc_description,
    di.doctype as docinfo_doctype,
    di.urltype,
    di.urlname,
    di.contentuid,
    di.createdate as docinfo_createdate,
    di.createby as docinfo_createby,
    p_di_createby.displayname as docinfo_createby_displayname,
    di.changeby as docinfo_changeby,
    p_di_changeby.displayname as docinfo_changeby_displayname
    from inspectionresult ir
    join inspfieldresult ifr
    on ifr.resultnum = ir.resultnum
    and ifr.inspformnum = ir.inspformnum
    and ifr.revision = ir.revision
    and ifr.siteid = ir.siteid
    left join inspquestion iq
    on iq.inspquestionnum = ifr.inspquestionnum
    and iq.inspformnum = ifr.inspformnum
    and iq.revision = ifr.revision
    and coalesce(iq.siteid, ifr.siteid) = ifr.siteid
    left join inspfield ifld
    on ifld.inspfieldnum = ifr.inspfieldnum
    and ifld.inspquestionnum = ifr.inspquestionnum
    and ifld.inspformnum = ifr.inspformnum
    and ifld.revision = ifr.revision
    and coalesce(ifld.siteid, ifr.siteid) = ifr.siteid
    join doclinks dl
    on dl.ownertable = 'INSPFIELDRESULT'
    and dl.ownerid = ifr.inspfieldresultid
    join docinfo di
    on di.docinfoid = dl.docinfoid
    left join person p_ir_createdby
    on p_ir_createdby.personid = ir.createdby
    left join person p_ifr_enteredby
    on p_ifr_enteredby.personid = ifr.enteredby
    left join person p_dl_changeby
    on p_dl_changeby.personid = dl.changeby
    left join person p_di_createby
    on p_di_createby.personid = di.createby
    left join person p_di_changeby
    on p_di_changeby.personid = di.changeby
    left join asset a
    on a.assetnum = ir.asset
    and a.siteid = ir.siteid
    left join locations l
    on l.location = ir.location
    and l.siteid = ir.siteid
    where ir.siteid = 'SRQSITE'
    and ir.inspformnum = '1014'
    and di.doctype = 'Images'
    order by
    ir.resultnum,
    iq.sequence,
    ifld.sequence,
    dl.createdate desc;
    Julia Scott
    Sarasota County Government
  • 2.  RE: MAS Cloud Attachment Access for PowerBI Inspection Image Dashboard
    Posted 3 days ago
    Julia,
    One way that we've used in the past to solve this problem is to create an automation script that can be called from the Maximo REST API. The automation script can be written to accept parameters, in this case maybe the INSPFIELDRESULTID. You can then fetch the attachment inside of the automation script, and if it is the appropriate type (JPG, PNG, etc.) return the binary image data in the response body of the script.
    Then you can configure most reporting tools to fetch a dynamic image from a URL, which in this case would be a link to the script with appropriate parameters and headers.
    Hope this helps,
    Alex Walter
    A3J Group LLC
  • 3.  RE: MAS Cloud Attachment Access for PowerBI Inspection Image Dashboard
    Posted 3 days ago
    Thank you so much for your reply---that's a good idea.  Do you know what supported API/class should be used to retrieve the binary content for a DOCLINKS / DOCINFO attachment stored in S3/COS, so the script can return it as image/jpeg or image/png in the HTTP response?
    Julia Scott
  • 4.  RE: MAS Cloud Attachment Access for PowerBI Inspection Image Dashboard
    Posted 2 days ago
    The REST API IBM Maximo Autoscripting Guide – Invoking script through Automation Script Handler enables you to set the content type.
    At the most basic level, you want to do something like this to retrieve the attachment contents & set the content type. I will add that you should be careful with this approach because any authenticated user can access any attachment if they know or guess the ID. You can reduce this to specific accounts or permissions to make it more restricted. This also assumes the image is a PNG (we have additional logic that converts & creates a thumbnail). You can guess content type based on extension.
    from com.ibm.tivoli.maximo.oslc.provider import AttachmentStorage
    doclinksid=request.getQueryParam("doclinksid")
    doclinkSet=service.getMboSet("DOCLINKS",request.getUserInfo())
    sqf=SqlFormat("doclinksid=:1")
    sqf.setObject(1,"DOCLINKS","DOCLINKSID",doclinksid)
    doclinkSet.setWhere(sqf.format())
    doclinkMbo=doclinkSet.getMbo(0)
    if doclinkMbo:
        attachmentStore=AttachmentStorage.getInstance()
        attachment=attachmentStore.getAttachment(doclinkMbo)
        responseBody=attachment
        responseHeaders.put("content-type","image/png")
  • 5.  RE: MAS Cloud Attachment Access for PowerBI Inspection Image Dashboard
    Posted 2 days ago
    Very much appreciated, Steven.  That is the key I was missing.
    Julia Scott
