Diane,
This is definitely a strange behavior especially if it is happening to multiple users. Here are a few things I would recommend to try to see if it clears the issue:
- Clear the browser cache and retry
- Use the developer tools on Edge or Chrome specific to the Maximo tab (Developer tools is active per tab). Have the console sub tab in developer tabs selected and see what it shows when you switch between tabs or switching between applications.
- For User 2 that is opening a second Maximo tab make sure that they are not copying the entire URL from the first tab/session. It should only be https://<hostname>/maximo when they launch a second tab
- To eliminate the server side being the problem, I would stop the Maximo application (schedule an appropriate downtime) and clear the Websphere Cache. I am not sure how yoru upgrade was done, but there potentially may be some stale cache files. If you have not done this before here are the folders you need to clean out and there are a few IBM Technotes like this https://www.ibm.com/support/pages/about-clearing-websphere-70-90-cache-files-maximo-administrators
Delete cached files from temp and wstemp and, optionally, logs directories:
Windows (where the WebSphere location is C:\Program Files\IBM\WebSphere\AppServer, the application server profile is called ctgAppSrv01, the node is called ctgNode01, and the Maximo server is called MXServer). *.* means contents of the named directory:
- C:\Program Files\IBM\WebSphere\AppServer\profiles\ctgAppSrv01\temp\ctgNode01\MXServer\*.*
C:\Program Files\IBM\WebSphere\AppServer\profiles\ctgAppSrv01\wstemp\*.*
(optional) C:\Program Files\IBM\WebSphere\AppServer\profiles\ctgAppSrv01\logs\MXServer\*.*
5. Before your restart Maximo after clearing the cache I would re-run UPDATEDB to be safe. A re-build and Re-deploy would also be a good option. You typically would not need to but not knowing how the Windows Upgrade was done and what other changes may have happened it can sometime save you the hassle.
6. One other item where I have seen many years ago was an Antivirus/Malware software a client installed. The corporate IT deployed a new software version which no one knew anything about and it caused havoc with the browsers and impacted Maximo.
Hope these suggestions help.
Mike
Michael Marsonet
MRM-EAM Consulting Inc.
