  • 1.  Maximo attribute and app.xml mapping
    Posted 04-16-2026 07:21
    Hello all,
    We have been asked to do an exercise to identify all the attributes in Maximo that are being used in the UI (app.xml).
    As there is no direct mapping available in Maximo wrt attribute and app.xml mapping we are looking for a feasible option to get this data. Any leads would be helpful
    Siva V
    Thiran Technologies
  • 2.  RE: Maximo attribute and app.xml mapping
    Posted 04-16-2026 13:05
    Are you talking about classic Maximo (Application Designer) or the new role-based applications (Maximo Mobile, Operational Dashboard, Inspection forms, etc.)? You mentioned app.xml which is normally associated with MAF.
    For Maximo Mobile apps, there is a concept of a schema (/maximo/oslc/graphite/mobile/schema) that provides you the attributes being fetched. It's still a bit of a matching game going through relationships, child objects in the object structure, etc.
    In classic apps, things also often go through relationships, special include datasources, etc. which is tricky
