  • 1.  Maximo Mobile
    Posted 04-24-2024 11:42
    Hi Team, i have a requirement to filter Maximo Mobile status or restrict statuses based on selected status
    uttam ibbandi
    ibm
  • 2.  RE: Maximo Mobile
    Posted 02-25-2025 00:29
    Hi Uttam,
    Here's an example of how it can be done. A bit late for you, but may help others looking for a similar solution.
    https://github.com/ibm-maximo-mobile-dev/mobile-scripting/blob/main/samples/changeStatus/sample02.js
    Cheers.
    Maycon Belfort
    BPD Zenith
    IBM Champion 2024
  • 3.  RE: Maximo Mobile
    Posted 02-26-2025 23:43
    Hi@Maycon Belfort
    We've made several changes in our mobile app's    .js files, but for migration purposes, manually updating each .js file is proving to be quite difficult. I would like to explore whether there is a way to consolidate all our changes into the appcustomization.js file.
    Could you please advise on the best approach to achieve this .
    samba mamidala
    techm
  • 4.  RE: Maximo Mobile
    Posted 03-06-2025 02:01
    Hi Samba,
    It depends on your customisations. It's difficult to say what the best approach is, but I was able to make many customizations using only the AppCustumizations.js file.
    A few simple things you can find on my mobile scripting repo: GitHub - ibm-maximo-mobile-dev/mobile-scripting
    If I had to choose the most important one, it would be the datasource manipulation. mobile-scripting/samples/datasource/sample01.js at main · ibm-maximo-mobile-dev/mobile-scripting
     I hope this can help you.
    Cheers.
    Maycon Belfort
    BPD Zenith
    IBM Champion 2025
