Maximo Mobile flow control issue.
  • 1.  Maximo Mobile flow control issue.
    Posted 03-01-2024 09:59
      |   view attached
    Hello Team ,
    In Maximo core for a work order under flow control with the predecessors if we are changing the 1st task status to COMP status then automatically the next WSCH task status is getting changed to INPRG. But from maximo mobile when the 1st task status is getting changed to COMP then automatically the next WSCH task status is not getting changed to INPRG and due to which error is coming at the time of completing WSCH status task.Ideally as per the Maximo cote system when 1st task status is getting changed to COMP then the next WSCH task status also should get changed to INPRG and after that we should be able to change the task status to COMP. For the 1st task after changing the status to COMP in maximo core it is getting updated to COMP but for next WSCH task status is not getting updated automatically to COMP in Maximo core.
    Please find the attached log file for reference.
    Biswa
    Biswaranjan Biswaranjan
    TCS
    Attachment(s)
    rtf
    Error.rtf   957 KB 1 version
