  • 1.  Maximo - Mobile MAS 9.0
    Posted 05-23-2025 10:57
    Edited by Hardik PAtel 05-23-2025 11:00
    I am trying to duplicate TECHMOBILE application but when i do that, i am getting this error message.  Anyone has solution to fix this error? Due to this, i am not able to modify application.
    [ERROR]: maximo-datasource-override is not a valid parent of mobile-referenced-load (id: x74dg). Valid parents include maximo-datasource
    [ERROR]: Failed processing the MAML file with error 'maximo-datasource-override is not a valid parent of mobile-referenced-load (id: x74dg). Valid parents include maximo-datasource'.  Use --verbose for more information.
    below is datasource from techmobile app:
     <maximo-datasource-override default="true" id="todaywoassignedDS" mobile-qbe-filter="{{'status_maxvalue': '!=COMP,CAN,CLOSE,WAPPR', 'assignment[0].status_maxvalue' : '!=WAITASGN'}}" offline-immediate-download="true" saved-query="ASSIGNEDWOLIST">
              <mobile-referenced-load id="x74dg">
    Hardik PAtel
  • 2.  RE: Maximo - Mobile MAS 9.0
    Posted 05-27-2025 12:41
    What is the exact version of Maximo Mobile you are deploying (IE 9.0.X, including the X component)? And what version of the config image are you using?
    I tested this with 9.0.9 (Manage & config image) and confirmed I don't see the issue on this version. A lot of customers grab the wrong image. Typically, they grab 9.0.0 since they see it here Downloading the Docker container image - IBM Documentation but that's only supposed to be if you are on 9.0.0 of Manage/Maximo Mobile 9.0 with no IFIX for EAM. The correct version of the image you are supposed to use is documented here: Configuring and customizing IBM® Maximo® Mobile
  • 3.  RE: Maximo - Mobile MAS 9.0
    Posted 05-27-2025 13:21
    Edited by Hardik PAtel 05-27-2025 13:22
    Hi Steven,
    Below is sandbox system info:
    App Server
    IBM WebSphere Liberty Server 24.0.0.9
    Server Operating System
    Linux 5.14.0-284.66.1.el9_2.x86_64 amd64
    Server Database
    Oracle 19.1 Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production Version 19.22.0.0.0
    Version
    Maximo Integration Framework 9.0.73 Build 20241119-0759 DB Build V9000-20 HFDB Build HF9000-04
    IBM Maximo Mobile 9.0.73 Build 20241119-0942 DB Build V9000-74 HFDB Build HF9000-17
    Maximo Application Framework 9.0.73 Build 20241113-2348 DB Build V7600-36 HFDB Build HF7600-21
    Manage Foundation 9.0.73 Build 20241119-0759 DB Build V9000-37 HFDB Build HF9000-02
    Maximo Manage 9.0.73 Build 20241119-0759 DB Build V9000-01 HFDB Build HF9000-12
    IBM Maximo Connector for SAP Applications 9.0.3 Build 20240930-1140 DB Build V9000-01
    Maximo Process Automation Engine 9.0.73 Build 20241119-0759 DB Build V9000-127
    IBM Maximo Health 9.0.60 Build 20241115-0419 DB Build V9000-28
    and I am using correct image. I followed steps documented in this article.
    Ibm remove preview
    Application Configuration is provided in a Docker container image.
    View this on Ibm >
    Hardik
    Hardik PAtel
