We have the report configured in birt to print the report but when we print the PDF with the Markup we get the PDF but not the Markup.
Its like birt doesnt know about the option to print with markup and I cant see a way of telling it to print with it
If you print direct from a PDF that is marked up, you get this option
Alan Michie
Sent: 09-13-2023 11:38
Subject: Maximo Print with attachments not printing bluebeam markup
Not very sure about your exact requirement.
You will do bluebeam or any other kind of markup on PDF outside of Maximo, say for example there is a manual and you have done markup there, then you can add that with desired record in Maximo as attachment. And then you can develop report in BIRT which also print that attachment which is markup. This report can be configured for direct print as well in Maximo.
If this doesn't fulfill your requirement then can you elaborate on the use case?
Sedin Technologies
#IBM Champion 2022
#IBM Champion 2023
