  • 1.  Maximo Server upgrade - Attachments update old attachments for the new servers
    Posted 01-25-2024 17:55
    Maximo Server upgrade - Attachments how do you update old attachments for the new servers - error when trying to view the old attachments
    Configuring the doclinks, via instructions on new servers. New attachments are viewable
    Copied the folder DOCLINKS to the new server from the old server
    updated the the manage folders for the new server
    The manage library has the old server name \\maxmo00p\DOCLINKS\ATTACHMENTS\20230426_075455.jpg
    tried updating a attachment via the library to the new server name  \\maxmo0Xp\DOCLINKS\ATTACHMENTS\20230426_075455.jpg
    How do you bulk update the attachments?
    Not Found
    The requested URL /ATTACHMENTS\20230426_075455.jpg was not found on this server.
    IBM_HTTP_Server at maxmo03p Port 80
    Diane Nohner
    City of Minneapolis
  • 2.  RE: Maximo Server upgrade - Attachments update old attachments for the new servers
    Posted 01-26-2024 11:01
    SQL update for this is the best approach. It's important that from a case perspective that everything matches identically. IE the system properties (mxe.doclink.doctypes.defpath, mxe.doclink.doctypes.topLevelPaths, etc.), DOCTYPES (Manage Folders), and DOCINFO (the individual attachments) need to reference everything the exact same way. IE \\maximo0xp\DOCLINKS will be handled differently than \\maximo0xp\doclinks and will lead to issues even if you are on platforms that are not case sensitive.
    I used to have a SQL update statement that went through DOCINFO to update all the attachments dynamically but a really simple version that would likely do what you need would be this:
    update docinfo set urlname=replace(urlname,'\\maxmo00p\DOCLINKS\','\\maxmo0Xp\DOCLINKS\') where urltype='FILE' and urlname like '\\maxmo00p\DOCLINKS\%';
  • 3.  RE: Maximo Server upgrade - Attachments update old attachments for the new servers
    Posted 01-26-2024 15:43
    Edited by Diane Nohner 01-26-2024 16:39
    Steve -  Thank you for the advise and expertise.  It worked perfectly.   Enjoy the weekend.
