Maximo server upgrade from Windows 2012 R2 to Windows 2016 or 2019 WebSphere 8.5.5.14 -Compatibility
  • 1.  Maximo server upgrade from Windows 2012 R2 to Windows 2016 or 2019 WebSphere 8.5.5.14 -Compatibility
    Posted 09-25-2023 14:19
    Were upgrading our application and integration servers from 2012 R2 to either 2016 or 2019
    Currently our database server is on SQL 2016.
    Is WebSphere version 8.5.5.X  compatible with  2016 or 2019 servers?
    According to the version matrix from IBM it looks like it is can someone confirm.
    Current - System Information
    App Server         IBM WebSphere Application Server 8.5.5.14
    Version
    Tivoli's process automation engine 7.6.1.3-IFIX20230324-1804 Build 20220823-0909 DB Build V7613-344 HFDB Build HF7613-67
    IBM Maximo Application Framework 8.8.0 Build 20220823-1257 DB Build V7600-23
    IBM Maximo Asset Management Scheduler 7.6.8.2 Build 20220823-0909 DB Build V7682-23 HFDB Build HF7682-08
    IBM Tpae Integration Framework 7.6.1.3 Build 20220823-0909 DB Build V7613-61
    IBM Maximo Spatial Asset Management 7.6.1.1 Build 20230406-1733 DB Build V7611-24 HFDB Build HF7611-07
    IBM Maximo Asset Management 7.6.1.3 Build 20220823-0909 DB Build V7611-01
    IoT Connection Utility 7.6.0.4 Build 20220303-1642 DB Build V7604-01
    Server OS           Windows Server 2012 R2 6.3
    Server DB           Microsoft SQL Server 13.0 (13.00.7024)
    (c) Copyright IBM Corp. 2021
    Diane Nohner
    City of Minneapolis
  • 2.  RE: Maximo server upgrade from Windows 2012 R2 to Windows 2016 or 2019 WebSphere 8.5.5.14 -Compatibility
    Posted 09-26-2023 11:47
    have an answer WebSphere version is not compatible with 2016 or 2019, need to update to WebSphere Application Server 9.0.5.
    Diane Nohner
    City of Minneapolis
