  • 1.  Maximo Work Centers Inspections - follow-up work order
    Posted 10-26-2022 13:18
    We are setting up Maximo Work centers. We use version 7.6.0.9
    We have a question on the 'Conduct an Inspection' process. We filled out the inspection we created and then click the 'CreateAWorkorder' command button. The only field to populate for this new work order is worktype.  Where can we add more fields to this step? Is this managed by an HTML file?
    #WorkCenters
    Daniel Beyler
    Allison Transmission
  • 2.  RE: Maximo Work Centers Inspections - follow-up work order
    Posted 10-27-2022 08:09
    Hi Daniel,
    yes it is possible, we are copy action (action that require WO creation) note to observation WO task.
    You can populate information from inspection form to WO with automation script.
    Thank you
    Chavdar
    Chavdar Cholev
    Home
