  • 1.  Message Engines of MIF and UI are not starting.
    Posted 01-30-2025 07:42
    Error message from DMGR logs:
    [1/30/25 13:30:15:433 AST] 00000054 AppGroupState I   HMGR1108I: Unable to make group consistent with the specified policy. There are no available members to activate. The group name is IBM_hc=MIF,WSAF_SIB_BUS=intjmsbus,WSAF_SIB_MESSAGING_ENGINE=MIF.000-intjmsbus,type=WSAF_SIB.
    [1/30/25 13:30:45:431 AST] 00000054 AppGroupState I   HMGR1108I: Unable to make group consistent with the specified policy. There are no available members to activate. The group name is IBM_hc=MIF,WSAF_SIB_BUS=intjmsbus,WSAF_SIB_MESSAGING_ENGINE=MIF.000-intjmsbus,type=WSAF_SIB.
    [1/30/25 13:33:57:201 AST] 0000014e webapp        I com.ibm.ws.webcontainer.webapp.WebApp log SRVE0292I: Servlet Message - [isclite#isclite.war]:.action: SIBMessagingEngineCollectionAction: Cannot start Messaging Engine MIF.000-intjmsbus:*:*
    Im also getting this error in websphere when i try to start the message engines manually:
    The messaging engine MIF.000-intjmsbus cannot be started as there is no runtime initialized for it yet, retry the operation once it has initialized. For the runtime to successfully initialize the hosting server must be started, have its 'SIB service' already enabled, and dynamic configuration reload enabled. If this is a newly configured messaging engine and it is the first messaging engine to be hosted on this server, then it is most likely the 'SIB service' was not previously enabled and thus the server will need to be restarted. The messaging engine runtime might not be initializing because of an error while trying to start, examine the SystemOut.log of the hosting server to check for error messages indicating the problem.
    But the SIB service is enabled in each JVM and i also did a complete restart
    #Infrastructure
    Hariprasad R
  • 2.  RE: Message Engines of MIF and UI are not starting.
    Posted 10-27-2025 17:47
    Hi Hari,
    This looks like the runtime is not started/initialized correctly.
    Tinnokesh AP
