  • 1.  Meter-based PM
    Posted 03-03-2025 14:15
    I'm trying to load a bunch of PM's that use meter-based frequencies. For some reason, both PMACTMETER and PMASSETWOGEN attribute values are ignored. Is there something I'm missing?
    Jason Johnson
    RSI
  • 2.  RE: Meter-based PM
    Posted 03-04-2025 08:28
    Hi Jason,
    Have you checked your object structure to ensure those attributes are not excluded? More Actions > Exclude/Include Fields
    Stevie Holloway
    Tufts University
  • 3.  RE: Meter-based PM
    Posted 03-04-2025 08:35
    I have had this issue in the past as well.  Make sure that the object structure is correct.  The PMACTMETER should be a 1 on the load sheet and the PMASSETWOGEN should be a 1.  The PMASSETWOGEN will only populate if you have the PMMETER.FREQUENCY input as well.  This needs to be on the load sheet as PMMETER.FREQUENCY because it is associated with a different table.  Hope this helps.
    Michael Guns, CRL, CEFP, CMRP
    JFC & Associates
    mguns@jfc-associates.com
  • 4.  RE: Meter-based PM
    Posted 03-04-2025 09:04
    Thanks for the insights about the object structures. I've checked and they are not excluded, though.
    And the PMMETER.FREQUENCY was a part of the load sheet.
    I've also tried inputting the values as numeric 1 and text 1.
    Jason Johnson
    RSI
  • 5.  RE: Meter-based PM
    Posted 03-04-2025 09:10
    Edited by Michael Guns 03-04-2025 09:10
    Last thing I can think of is what Steve suggested.  Make sure the attributes are not excluded in the object structure and make sure there is a relationship for the PM and PMMETER tables.  There should be but it is always safe to check.
    JFC & Associates
  • 6.  RE: Meter-based PM
    Posted 03-05-2025 00:24
    Hello Jason,
    It should work...
    It isn't easy to understand the cause of your problem without looking at the file.
    Can you share the MxLoader file with a sample of data?
    Sadok ABDELLAOUI
