  • 1.  Modifying WFNOTIFICATION.MESSAGE with Autoscript
    Posted 09-24-2025 15:27
    Hi Folks,
    Using Maximo 7.6.1.3, we currently we have an Automation Script that is tied to the COMMLOG.MESSAGE attribute which updates a placeholder (#TEXTHERE#) in the Message Body of the CommLog with a table of child records associated to an SR. This works flawlessly when the Communication Log is invoked via the user in the UI.
    In configuring and testing a Workflow which is looking to leverage this same template, I'm hoping to tie this same script via a separate launchpoint to catch the emails that are being sent as part of our Workflow Task Node Notification that come from WFNOTIFICATION object. There MESSAGE is a non-persistent field, and my initial attempts to catch this with an OBJECT INIT script have been unsuccessful.
    Just checking to see if anyone else has done this before? Or if I should be looking at an alternative approach?
    Cheers,
    Matt F
  • 2.  RE: Modifying WFNOTIFICATION.MESSAGE with Autoscript
    Posted 10-11-2025 07:17
    Hi Matt,
    Did you try with attribute launchpoint with 'Action' event?
    Thanks!
    Sankar Ganesh V S
    DXC Technology
  • 3.  RE: Modifying WFNOTIFICATION.MESSAGE with Autoscript
    Posted 10-11-2025 08:53
    Hi Sankar,
    Thank you for the reply. This is how I'm setting it on the COMMLOG.MESSAGE script, but I have not had success on the WFNOTIFICATION.MESSAGE attribute with the same type of event. On WFNOTIFICATION, MESSAGE is non-persistent with an associated class (psdi.workflow.FldNotifyText) which I believe is conflicting with my attempt to intercept the body of the email.
    Matt F
  • 4.  RE: Modifying WFNOTIFICATION.MESSAGE with Autoscript
    Posted 10-11-2025 09:20
    Then, I would suggest triggering an action script with communication template.
    You can refer this example.
    To update the '#PlaceHolder#' , Get the COMMTEMPLATE.MESSAGE and use string replace function.
    Hope this helps.
    Thanks!
