Monitor Temperature & Humidity with ESP8266 and Maximo Monitor
  • 1.  Monitor Temperature & Humidity with ESP8266 and Maximo Monitor
    Posted 02-08-2023 08:29
    Edited by Prashant Sharma 02-08-2023 09:31
    Maximo Monitor is an application in Maximo Application Suite (MAS) which provides a monitoring solution for real-time visibility, root-cause troubleshooting, anomaly detection, and AI-driven alerts at scale. With Maximo Monitor, users can visualize current and historical trend data for their assets and associated devices in customizable dashboards.
     In this use case we’ll see how we can monitor Temperature and Humidity data in a room using ESP8266 and Maximo Monitor.
     ESP8266 is a low-cost Wi-Fi microcontroller chip used as a development board for IoT (Internet of Things). We are connecting Temperature and Humidity Sensor with ESP8266 and sending data to Maximo Monitor.
    In Maximo Monitor we have created device ESP8266 and generated an authentication token which shall be used to connect and authenticate with Maximo Monitor. After that we have associated Device with existing Organization Hierarchy.
    Now user can go to the Device and setup dashboard where output is displayed on value cards, tables, images, line graphs, and alert tables which can be configured on basis of different metrics. In this dashboard we have used Time Series graph for Temperature Reading, a Simple bar for Humidity reading, Stacked Bar for Temperature & Humidity Reading, and an Alert table to show alerts created.
    Read the blog for more details. Have any further questions, connect with me on LinkedIn.
    #EverythingMaximo #monitor #apm #IoT #iiot #mas #predictivemaintenance #conditionmonitoring ​​#MaximoApplicationSuite
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
