  • 1.  MultiSelect Databean on Maximo Java customization
    Posted 02-13-2023 07:29
    Here is a requirement like, have to create a multiselect dialogue box to select the records of items from service items table and place in work order application. Can anyone one please assist here
    I am new to using the databean, appbean, Multiselectdatabean, and I am open to suggestions for better solutions.
    Thanks in advance
    Bhuvana K
    Bhuvana G
  • 2.  RE: MultiSelect Databean on Maximo Java customization
    Posted 02-14-2023 07:19
    Your requirement is not very clear. How do you want the dialog box to open, and what all columns will be in the dialog box? It will be a good idea to provide more details to avoid open-ended questions.
    Anyways, this article should help - http://maximoaddons.com/blog/how-to-create-a-real-multi-select-data-bean-in-maximo.html
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 3.  RE: MultiSelect Databean on Maximo Java customization
    Posted 02-14-2023 07:53
    If you want an automation script solution (to avoid needing to write java classes), I have this blog post walking through how to do it. https://community.ibm.com/community/user/asset-facilities/blogs/steven-shull/2022/06/01/multi-select-support-via-automation-scripts?CommunityKey=ed77c224-45e2-47b0-b574-cc31496f9a41
