  • 1.  MXloader to load MATUSETRANS
    Posted 05-31-2024 10:35
    I am trying to load some material returns for matusetrans. I keep getting a BMXAA4214E - An unknown error has occurred result. Here is a picture of the columns I am using. Am I missing any columns that would cause this? Is this setup incorrectly?
    Any help is appreciated.
    MXloader
    Ted Krasavage
    N2
  • 2.  RE: MXloader to load MATUSETRANS
    Posted 06-10-2024 21:07
    Hi Ted,
    I've assumed straight away that you're missing key fields.  Also, I would use REFWO rather than WONUM (one's persistent).  It would normally check the primary columns using Database Configuration, but that is not telling the correct story in this can.  Have a look at the below index and see if adding these feilds resolve your issue.
    Principal Consultant
    COSOL
    #IBMChampion
