  • 1.  Need help with application creation
    Posted 08-10-2025 18:48
    I need help on creating a new application on Maximo DEV as our dev environment has been upgraded:
    The UI has changed but when I try to import the .xml file into a new app that I am trying to create, I get the following error:
    I then go to Create a new application definition:
    When I click on the magnifying glass, it does nothing :
    This is where I need help on creating a new application.
    #WorkCenters
    gursev bajwa
  • 2.  RE: Need help with application creation
    Posted 08-11-2025 20:41
    On the "Create a New Application" dialog, the "Main Object" should be the name of the object rather than an application name.  Try changing WOTRACK to WORKORDER for the Main Object, and then the lookup for Attribute should show a list of attributes for the WORKORDER object to select from.
    Adam Jensen
