  • 1.  NextGen REST API vs AddChange
    Posted 02-20-2024 13:11
    with the NextGen REST API, do you have any idea what combination of request method and the 'x-method-override' and 'patchtype' headers is required to achieve behaviour identical to the Synch&AddChange of the MIF (link)
    That is:
    - create the record if it does not exist
    - update the primary record if it exists
    - update sub-records if they exist
    - leave sub-records not included in the request intact
    Diego Visentin
    Tempestive S.p.A.
  • 2.  RE: NextGen REST API vs AddChange
    Posted 02-22-2024 11:14
    Hi Diego
    • Create the record if it does not exist: POST call with Params
    • Update the primary record if it exists: POST call with Params for a record ID and x-method-override : PATCH
    • Update sub-records if they exist & leave sub-records not included in the request intact : POST call with Params for a record ID and x-method-override : PATCH and patchtype:MERGE
    Framework matches child and update if finds match, otherwise leave them as it is or add new child if not found associated with Parent.
    Hope this clarifies.
    Sedin Technologies
    Learn Maximo with me @https://www.youtube.com/@reliabilityodyssey/
    #IBM Champion 2022
    #IBM Champion 2023
    #IBM Champion 2024
  • 3.  RE: NextGen REST API vs AddChange
    Posted 02-22-2024 11:44
    Hi Prashant ,
    t
    hank you for the summary which confirms what I knew.
    That's exactly why I was looking for a single REST API call that would work like the MIF Sync-AddChange.
    Thanks to a suggestion from @Biplab Choudhury I tried the BULK method and from initial tests it seems to address my requirement well.
    Diego Visentin
    Tempestive S.p.A.
