  • 1.  Object Formula in DataBase Configuration
    Posted 03-12-2025 05:31
    Hi Team,
    In DataBase Configuration , A Select Action Add/Modifiy Formula for Object is there.
    In this Dialog, we use to define formula with expression wrf Object/Mbo.
    May I know how to validate these Object Formula in application ?
    JustIn goodLuck
    ABS
  • 2.  RE: Object Formula in DataBase Configuration
    Posted 03-13-2025 22:08
    These can be tested within Health if you have it installed. Or you can use the REST API https://ibm-maximo-dev.github.io/maximo-restapi-documentation/query/selecting#formula-properties
    We don't provide another way to test it out of the box today. You can't use a formula in the classic UI for example.
