  • 1.  OIDC authentication in MAS 9.1 using Login.gov
    Posted 02-25-2026 11:11
      Has anyone successfully configured OIDC authentication in MAS 9.1 using Login.gov Sandbox? We receive an Invalid format error from the OIDC configuration panel in MAS when we enter the Client ID value from Login.gov, and haven't found a way to tweak the configuration in OpenShift to get past this. Does anyone have this working in their MAS 9.1 environment? Any guidance would be greatly appreciated.
    --Kenneth
    #Security
    Kenneth Frohne
    Segue Technologies
  • 2.  RE: OIDC authentication in MAS 9.1 using Login.gov
    Posted 03-02-2026 16:18
    Please vote for RFE (MASM-I-1774 - Add support for OIDC authentication in MAS 9.1 using Login.gov) on the Ideas Portal using the link below. Thanks!
    --Kenneth
     https://ibm-ai-apps.ideas.ibm.com/ideas/MASM-I-1774
    Kenneth Frohne
    Segue Technologies
  • 3.  RE: OIDC authentication in MAS 9.1 using Login.gov
    Posted 03-04-2026 09:19
    I'm not sure if this was your support ticket or someone else's but it looks like IBM accepted it as a defect: Known Issue: DT464321
  • 4.  RE: OIDC authentication in MAS 9.1 using Login.gov
    Posted 03-05-2026 10:21
    Hi Steven,
      Yes, the Support Case I opened was accepted as the Known Issue you identified. I will update this thread after we get OIDC authentication working with Login.gov and share any lessons learned with the community.
    --Kenneth
    Kenneth Frohne
    Segue Technologies
  • 5.  RE: OIDC authentication in MAS 9.1 using Login.gov
    Posted 03-11-2026 10:39
    Hi Kenneth Frohne,
    Were you able to successfully implement OIDC at your end. We are also trying for one of our instance.
    Other than this particular bug, Any new challenges you faced.?
    https://www.ibm.com/mysupport/s/defect/aCIgJ000000B1tdWAC/dt464321?language=en_US
    Lohit TR
    TCS
  • 6.  RE: OIDC authentication in MAS 9.1 using Login.gov
    Posted 03-12-2026 10:12
    Hi Lohit,
      No new challenges yet. We are waiting for resolution of Known Issue DT464321 - it is a hard block for implementing OIDC using Login.gov as the IdP.
    --Kenneth
    Kenneth Frohne
    Segue Technologies
