  • 1.  OpenStreet map not loading when previewing mobile app in MAS 9.1.4
    Posted 10-16-2025 04:44
    Hi everyone,
    I just upgraded to MAS 9.1.4 and noticed that the map no longer works when I preview a mobile app from the "Application configuration" app.
    What I have configured
    I have a Map Manager configured as follows:
    • Map: <autonumber>
    • Description: openstreetmap
    • Length and Distance Unit: Kilometers
    • Enable map: true
    • Map provider name: Open Map
    • MAF map component: true
    • Open Map provider: Open Street
    • Basemap URL: https://tile.openstreetmap.org/{z}/{x}/{y}.png
    • Map Initial Extent:
      • Site: BEDFORD
    I edited the "mxe.sec.header.Content_Security_Policy" system property and added the OpenStreetMap hostname to the following directives:
    • img-src;
    • frame-src;
    • connect-src;
    Expected behavior
    The map works in:
    • Desktop applications (asset, locations, workorder, ecc...)
    • OOB published mobile applications
    • OOB mobile applications previewed from the "Application configuration" app.
    Current behavior
    The map works in:
    The map does not work in:
    • OOB mobile applications previewd from the "Application configuration" app.
    Findings
    While previewing a mobile application, in the map view I opened the browser console to look for clues.
    I noticed that all the calls to OpenStreetMap were blocked due to CSP (Content Security Policy) errors:
    This may be related to changes made in the "Maximo Application Framework Configuration Tool", but I'm unsure which version first introduced this issue.
    I switched from using the Docker image to customize Graphite mobile apps (in MAS 9.0.x versions) to using the integrated application in Maximo Manage (in the MAS version 9.1.4.)
    Has anyone encountered this issue and/or knows if I'm missing some configuration?
    Yuri Vedovato
    Tempestive
  • 2.  RE: OpenStreet map not loading when previewing mobile app in MAS 9.1.4
    Posted 01-07-2026 10:23
    This is an older post so I apologize for not responding sooner but there was an issue with the new MAF app posted here: Known Issue: DT455951
  • 3.  RE: OpenStreet map not loading when previewing mobile app in MAS 9.1.4
    Posted 01-07-2026 10:36
    Hello Steven,
    Thank you very much for the information. I will keep an eye on the Issue.
    Yuri Vedovato
    Tempestive
