PRs not reopening from close to approved status after maximo upgrade to 7613
  • 1.  PRs not reopening from close to approved status after maximo upgrade to 7613
    Posted 06-15-2025 01:03
    Current system information
    App Server IBM WebSphere Application Server 9.0.5.22
    Version
    Tivoli's process automation engine 7.6.1.1 Build 20190514-1348 DB Build V7611-365
    IBM Maximo Asset Management Work Centers 7.6.0.4 Build 20190514-1348 DB Build V7604-119
    IBM Maximo Enterprise Adapter for Oracle Applications 7.6.0.0 Build 20150804-1717 DB Build V7600-05
    IBM Maximo Asset Management Scheduler 7.6.7.3 Build 20190514-1348 DB Build V7673-73
    IBM Maximo for Oil And Gas 7.6.1.0 Build 20161020-0803 DB Build V7610-139
    IBM Tpae Integration Framework 7.6.1.1 Build 20190419-2330 DB Build V7611-01
    IBM Maximo Asset Management 7.6.1.1 Build 20190514-1348 DB Build V7611-01
    SWG Tree Addon 7.6.0.0 Build 20180831-0900 DB Build V7600-09
    IoT Connection Utility 7.6.0.2 Build 20190426-2206 DB Build V7602-07
    BPD Zenith Logistics 7.6.1.0 Build BUILD DB Build V7600-31
    Server OS Windows Server 2016 10.0
    Server DB Microsoft SQL Server 13.0 (13.00.6455)
    System information after the Maximo fix pack upgrade
    System Information
    App Server IBM WebSphere Application Server 9.0.5.23
    Version
    Tivoli's process automation engine 7.6.1.3-IFIX20250227-1503 Build 20220823-0909 DB Build V7613-344 HFDB Build HF7613-169
    IBM Maximo Application Framework 8.8.0 Build 20220823-1257 DB Build V7600-23
    IBM Maximo Asset Management Scheduler 7.6.8.2 Build 20220823-0909 DB Build V7682-23 HFDB Build HF7682-13
    IBM Tpae Integration Framework 7.6.1.3 Build 20250227-0738 DB Build V7613-61
    IBM Maximo Asset Management 7.6.1.3 Build 20220823-0909 DB Build V7611-01
    IoT Connection Utility 7.6.0.4 Build 20220303-1642 DB Build V7604-01
    Hello all need an assistance on one issue we faced after doing the Maximo core and oil and gas upgrade from 7611 to 7613 and oil and gas from 761 to 762. We have interface table integration with oracle and pos cancelled in oracle are getting interfaced to Maximo but the corresponding pr is not reopening from close to appr status . Searched the entire repository of ibm could not find any such defect in version 761 as its there in 75 . Moreover in 761 we didn't face this issue for years together . After debugging all the integration related oob classes the only exception we saw is the event status change .pr.appr is failing but there are so many integration classes oob and it is not an easy task to see which class has broken . Any suggestions what we can do . Thanks a lot
    Mahadevan
    Mahadevan Ramakrishnan
Watch Episode 6
