  • 1.  Queries to compare two version of workflow
  • 2.  RE: Queries to compare two version of workflow
    Posted 08-01-2022 19:01
    Could you please provide additional information?
    Are you trying to determine which workflow (Process) is active on a work order?
    Are you trying to see which work orders have which version of the same workflow process?
    What are you two environments? SQL? DB2? Oracle? or MAXIMO 7.6.0.9 versus MAXIMO 7.6.1?
    What have you tried so far?
    Nikolaus Despain
    Aquitas Solutions
  • 3.  RE: Queries to compare two version of workflow
    Posted 08-09-2022 00:53
    Hi Aayushi,
    Are you looking for the queries on the workflow tables?You can run the query on any two versions and compare the output.Pls let me know if this is the correct understanding.
    Thank you.
    Mahadevan Ramakrishnan
